Are the 1LE springs different than stock?
Yes, they are different if they are the original ones that came with your 1LE. About two or three years ago, I heard GM went to the same stock number for 1LE and stock springs, but I haven't confirmed this. If so, it would make it hard for you to get true replacements - you'd get stuck with the stock crap.
If you need replacements, you might check out what SLP put out in their 1LE packages in later years.
Great car. Never sell it.
1LE.net gives all the part #'s for the parts used and lists the 98-99 fronts for LS1 at 360 #/in rate and the rears are progressive at 130-170 #/in. There are several other lists of spring rates on the WEB. Here is one: http://www.angelfire.com/my/fastcar/suspension.html
