Tire Alignment spec question
Old Apr 4, 2006 | 07:22 AM
Weezzer's Avatar
Default Tire Alignment spec question
I need clarification on the suggested alignment specs for the wheels.
The car has Koni’s on the front and I’m using the lower spring perch. I believe this makes the front end drop approx. 5/8”. Everything else is pretty much stock.
The GM preferred specs are:
Front
Caster 4.8
Cross Caster 0
Camber 0.4
Cross Camber 0
Sum Toe 0
Steering Wheel Angle 0
Rear Sum Toe 0
Thrust Angle 0
Now for the question, some people here have recommended the following changes:
Caster changed to 4.5
Camber changed to -0.1 to -0.5
Toe changed to 0 to 1/16” toe in
I’m a little confused about the “toe in”, I assume this is listed under the GM specs as Sum Toe and the GM range is listed as -0.2 to 0.2. If I go with the middle of the recommended toe change at 1/32” toe in, how does this equate into the GM rage of -.2 to .2? Is the -.2 to .2 in inches (as -.200” to .200” or is this an angle representation)?
Also, if I go with the suggested changes, are the other specs to remain at the GM preferred spec?
I’m to get my car aligned this afternoon and I sure would appreciate any help in this matter.
TIA
Old Apr 4, 2006 | 08:00 AM
trackbird's Avatar
If you walk in and give the tech these specs:
He'll use the GM stuff for the rest and it would look something like this:
Front
Cross Caster 0
Cross Camber 0
Rear Sum Toe 0
Thrust Angle 0
You'll be just fine, just give him the info from the top of this page, he'll handle the rest.
Old Apr 4, 2006 | 10:30 AM
Dom's Avatar
Dom
Are those the recommended specs for a daily or a weekend racer? I don't want to wear out my tires unevenly.
Old Apr 4, 2006 | 12:01 PM
Weezzer's Avatar
Front
Cross Caster 0
Cross Camber 0
Rear Sum Toe 0
Thrust Angle 0
Thanks Trackbird-I appreciate it.
Old Apr 4, 2006 | 12:38 PM
trackbird's Avatar
That's a good performance "street/driver" alignment.
For reference, I was running -1.3 camber, 4.5 castor and 1/32" of toe out (0 toe wears tires less than toe out) and I got 30K out of my front tires.
I'm now running -1.7 camber, 5.1 castor and 1/32nd inch of toe out and my tire wear has increased a fair amount (I'll still get 18-20k out of front tires from the looks of things). My car is daily driven, but the -1.7 camber is more of a weekend racer setup, not so much for drivers.
