Koni, Koni, Koni
if your considering lowering or not they can and will do the job.....there are other options to Koni's..it just depends on how extreme you want to be.....or flexable you need you sysyte mto be....alot of people get along just fine with Bilstiens..about 1/2 the price of the SA Konis....Re-valving Bilstiens are another option for as bit more....but still less $$ than Koini's....You geta better Bilstien and it can be custom valved for how you intend to use the car....But They lack the flexability you'll find in SA/DA Koni's..all have their place and represent a comprimise someplace...
There's a sticky in this section that shows various springs and how they look and the approx drop...If lowering some is what you want to do..
Different springs offer different spring rates which affect how the car will handle..first consider how your going to use the car yourself....
If should bump into Mr Strano he's always ( I dont know how) got time to talk suspension..you might want to pick his brain for ideas..he's also a sponsor...
I went with Re-valved Bilsteins mostly because of budget.....and I like them allot. Ive also lowered my car using G2 springs because I wanted a very firm ride..I dont imageing that they are the end all springs..Just my particular choice....Im more into running in the mountains thru the twists and wanted a suspension that could take quick transitions well
The G2's gave me a ~2" drop at all four corners..as soon as Sam ships them...Ill be running a set of his sway bars as well..the rest of my stuff is in my tag line
Hotchkis springs with Koni SA's.
I chose the springs because *TO ME* the ride height is perfect. It's not so slammed that it looks like I should have my last name in gothic letters across the back window (HERNANDEZ), but is definitely lower than stock. I was running them with KYB GasAJusts and the ride was...well...have you ever been on a small fishing boat during high tide?
I love my setup now. I feel large bumps ONCE, smaller bumps only at the tires. Turns are very predictable (I'm running slightly larger sway bars) and it's a night and day difference from stock and from the KYB shocks. They were very worth it to me. It made me fall in love with driving the car all over again.
-Mike
In the back I had the SA's set at full max and it was too stiff. So I backed up half a turn from full firm. The fronts I am still playing with. Started super soft and the ride was super bouncy. Went up on firmness and I am slowly getting there. Next up is half more turn of firmness. Not sure what my total turn count is up front.
BOSS APPROVED!
