any pic's of koni's sa or da?
I'm looking for detailed pics if anyone has them of the koni's sa and da shock's. I'm looking for the whole shock as well as close up of the ajusting **** and their positions on the shock body. also if anyone has a pic on the car as well that would help too. I'm working on another project and got myself a idea and would like a few good pic's to see how there are set and see if they might be worth my time doing a little moding thank's in advance
Check SLP's website or http://www.frrax.com
I don't have any off the car, but here are the only ones I could find.
Rears on my T/A
This is the stock front Koni on my old '98
Rears on my T/A
For Koni SAs, there is one removeable **** you use to adjust the rear shocks from inside the car. The two front shocks are not adjusted with a ****. You poke something like an allen wrench or small screw driver into a slot and twist the adjustment shaft (adjustment shaft has small holes in it.) This adjustment is near the top end of the shock, but inside the wheel well, not in the engine bay.
