Bad torque arm causing "clunk"?
Old Apr 14, 2006 | 08:52 PM
Chaotic Firebird's Avatar
Default Bad torque arm causing "clunk"?
I have a weird clunk sound. When I'm slowing down for a stop, and the tranny downshifts from 2nd to 1st, a hear a clunk sound. I know it isn't the trans mount since it's polyurethane and I just had it checked out today, everything was tight. Could a bad torque arm bushings, loose bolt, cracked torque arm be causing this clunk?
Old Apr 16, 2006 | 10:17 AM
Duffster's Avatar
not doubting you checked, but I had this happen when I snapped the upper bolt holding the stock torque arm to the T-56. . .
torque arm kept hitting the tunnel and would bounce back into place in the cheap rubber mount. . .
Duff
Old Apr 16, 2006 | 07:23 PM
Anyone else?
Old Apr 16, 2006 | 07:48 PM
Hangman's Avatar
2 things I had come loose-bolts holding the t/a to the diff. was causing that kind of sound when coasting over bumps, the other was the nut holding the tranny mount to the cross member.
Old Apr 17, 2006 | 03:50 PM
z_speedfreak's Avatar
check out your LCA's. I had a clunk on acceleration from blown bushings once
Old Apr 17, 2006 | 03:59 PM
I don't think it's my LCA's. I had Spohn peices installed last year with poly bushings.
Old Apr 18, 2006 | 06:19 PM
Marc '99T/A's Avatar
Duff
Exact same thing happened to me!!!! Freaking pain in the ***!
Old Apr 19, 2006 | 06:53 PM
Duffster's Avatar
Not really. . .I convinced my wife that i needed a new torque arm
Not bad replaced a 3 dollar bolt with a near 300 dollar torque arm
Old Apr 19, 2006 | 08:34 PM
Yeah, I got a used BMR torque arm relocation bracket from someone off the site. I didn't want to drop the transmission just to re-tap the hole.
Old Apr 20, 2006 | 07:29 PM
Whisper's Avatar
i had the same clunk I believe. I think someone suggested it was a throw out bearing-whatever the hell that is.
Old Apr 21, 2006 | 12:28 AM
If it's the same clunk that me and Duff had, it's real easy to tell; just get under the car and look at the bracket where the torque arm mounts to the transmission tail housing. If it's broken, there's the reason for your clunk.
Old Apr 22, 2006 | 05:10 PM
Duffster's Avatar
if you can push the T/A up or pull it down (most likely pull down) then it's busted. . .
(just hit my 200th post. . .finally Launching. . . )
Old Apr 22, 2006 | 06:05 PM
ws6formula98's Avatar
My car does the same, I got new TA, LCA, and every thing else looks ok..I will check the transmission mount next..
Old Apr 22, 2006 | 07:01 PM
Not so much the tranny mount as it is the bracket where the TA mounts to the transmission.
Old Apr 23, 2006 | 10:39 AM
Duffster's Avatar
It would have to be a DAMNED STRONG engine to cause the tranny to bounce
Just guessing 800+ FtLbs. . .
Old Apr 23, 2006 | 12:36 PM
black01_WS6's Avatar
I have had this problem with my spohn TA, all I do is get up underneath, and tighten the hell out of the bottom bolt, thats what spohn said to do and it solved the problem.
Old Apr 23, 2006 | 01:35 PM
Thanks guys. I'll have the torque arm looked at when I get my new tires installed.
