improving the 60
Old Apr 15, 2006 | 02:20 AM
AW794's Avatar
Default improving the 60
Becids drag radials, and SFC's what can i get to improve the 60? Torque arm? Shocks, springs? LCA's? I dont have wheel hop, just spins out of the hole. Thanks
Old Apr 15, 2006 | 02:32 AM
RA4926's Avatar
when i put my panhard bar and lca's in i got a bit more traction, and ive heard torque arms do alot for off the line too. btw umi performance has lca's and panhard for like $160....good products but it took 2 weeks for my last 2 orders to ship
Old Apr 15, 2006 | 06:32 AM
Dragula's Avatar
Are you using DR currently or are you trying to avoid them. I had all my mods in my sig except DR and didn't improve my 60' until I put them on.
Old Apr 15, 2006 | 08:27 AM
UMI Performance's Avatar
Sorry about that, but thanks for the orders. LS1tech is just keeping us to busy to keep up
With racing season here it is very hard to keep all items in stock but we are doing are best. Thanks again!
Ryan
Old Apr 15, 2006 | 12:44 PM
davered00ss's Avatar
Moderator
Drag radials aren't really a great improvement for traction. At least not the Nitto's. I cut an ave. 1.97 60' on Yokahamma street tires & a Best of 1.96 on Nitto's.
Old Apr 15, 2006 | 02:05 PM
jmm98LS1's Avatar
Put some mickey thompson drag radials on there. If you don't see an improvement, you're not pushing the gas hard enough!!
Old Apr 15, 2006 | 03:46 PM
Jaspirr's Avatar
I'll second that. I replaced my Nitto 555R's with Mickey Thompson radials yesterday and it dead hooked even with a 4000 RPM clutch drop.
Old Apr 16, 2006 | 03:16 AM
camaroextra's Avatar
yeah mickey thompsons>nittos
get lca's with relocation brackets
Old Apr 16, 2006 | 05:16 AM
ss1129's Avatar
I hit 1.8 on them with an m6 at 14psi. So Im happy, plus I will get my money out of them on the street too.
Old Apr 16, 2006 | 08:50 AM
Moderator
I'd like to get a set of the MT drag radials.
Old Apr 16, 2006 | 09:38 AM
SSPEEDY's Avatar
1.66 60ft with mods in sig. 22 psi (what i run on the street). Not bad for a 17" drag radial.
Old Apr 16, 2006 | 05:06 PM
AW794's Avatar
I currently have nitto street tires, with UMI 2pt SFC's. Stock shocks, springs and all suspention parts. Best 60 is a 2.3 on many launches. I cant seem to get ANY better at it.
I have a 10 bolt, and refuse to launch hard with it for now. Im probably making 330 to the wheels and want to get that power to the pavement before i do any other HP mods.
I heard removing the front swaybar helps?
Car is a M6.
Thanks
Old Apr 16, 2006 | 05:08 PM
Car is a M6.
Thanks
ditch the crappy stock shocks, and get some lca's with relocation brackets, and your 60' will plummet
Old Apr 24, 2006 | 11:20 AM
SSPEEDY's Avatar
all the suspension mods in the world won't do a lick of good without a stickier tire. I threw on my stock tires one day (i have lca's, torque arm, phb, stock springs/shocks) and it spun just as bad as it did before my suspension mods. suspension parts help the sticky tire do it's job better.
Old Apr 30, 2006 | 08:56 PM
redhotz28's Avatar
what kind of shocks and springs do you guys recommend?
Old Apr 30, 2006 | 10:41 PM
rotwiler's Avatar
Running street tires that were pretty good off the line I managed a best of 1.94* 60 foot. The very first day at the track with Nitto DR's I pulled a 1.72*, so the Nittos made a huge difference. Have to get them smoking hot, but when they are they hook great. With no additional mods and before the Nitto's I seen the exact same 60 foot times with Bilstein shocks as I did with the stock ones, but overall handling is much better with the Bilstein's.
Old May 1, 2006 | 09:53 AM
seadoo's Avatar
i pulled 1.58 60' stock suspension on 26" MT DR's- 4K stall
now i have new bilstein hd's, chassis mount adj. t/a, boxed, lca's, tubular phr and skinnies up front...
I hope to make it down to 1.56 range
Old May 1, 2006 | 11:54 AM
ohsofast's Avatar
I pull 1.6 all day with Nitto's, all you have to do is heat them up, not throw the rocks off of them.
