KYB Agx
Shocks dont change the hieght, just control the travel up and down. You would be better off with bilstien revalves or Koni yellows like i have.
AFA the KYB AGX's, I don't care for them since the adjuster is a double-action single adjuster. Yes it simultaneously adjusts both rebound and compression, but the rebound is the key importance for many driving apps, not the compression, since it's very difficult to improve on controlling the vehicle's unsprung weight much more than what is present. That's why I prefer Koni's (when I was still using DA's) over all of the other "OE style mount" replacement upgrade shocks for the 4th gen. The non-ajustible compression valving is quite okay for the Koni SA. The rebound, which control's the sprung weight is the most critical part for many different F-bodies.
Just make sure you don't have a dumbass friend put the setting of the right front shock on 3 while you have the left front on 7.
Have fun with heavy (emergency) braking with that set-up, then have fun beating the crap out of your friend when your right side goes an extra 4 feet and your left plays catch-up.
Otherwise they are cheap and work if you don't want to spend a f$cking fortune.
