alignment specs with DMS & Koni
Old Apr 23, 2006 | 11:25 AM
BLCKBRD's Avatar
Default alignment specs with DMS & Koni
I'm going to be installing a set of DMS springs with Koni SA shocks on my WS6. I know I need an alignment after, but what should the alignment specs be set at? Should I go with just the normal factory settings or should it be set at something different since it will be lowered. The car is mostly street driven, and maybe at the track a few times a year.
Thanks.
Old Apr 24, 2006 | 09:56 PM
BLCKBRD's Avatar
Anyone have suggestions on what the camber, caster, and toe should be set at?
Old Apr 25, 2006 | 01:03 PM
BlackMafia's Avatar
I'm currently running DMS & Koni's in the front also and would like to know the specs concerning the allignment also. Thanks
Old Apr 25, 2006 | 03:58 PM
wvaboy's Avatar
camber set to -.5
caster stock is fine, but as much positive as possible
tow 0 to 1/16 tow in......more than that will wear on inside of tire.
Old Apr 25, 2006 | 09:41 PM
BLCKBRD's Avatar
ok, thanks wvaboy.
Anyone else have suggestions?
Old Apr 26, 2006 | 07:07 AM
BlackMafia's Avatar
Yeah thanks alot wvaboy. Really appreciate it man.
Old Apr 26, 2006 | 02:30 PM
wvaboy's Avatar
thank mr strano, that's who helped me help you
