oem ride height
Old Apr 23, 2006 | 05:43 PM
ZDOG's Avatar
Default oem ride height
can a car at stock height be made to handle as good as a lowered car? whats the best blend for straight line and twisties? thanks
Old Apr 23, 2006 | 08:58 PM
tc3's Avatar
tc3
if you want good handleing in turns and good launches, stock springs should be fine, just depends on what shocks/rollbars you go with...
i believe sam runs stock springs with koni's and roadraces...
Old Apr 24, 2006 | 07:57 AM
black01_WS6's Avatar
I have a set of qa1 adjustable shocks. can have it for twisties or track. and its not hard to change the settings.
Old Apr 24, 2006 | 08:22 AM
J. Brown's Avatar
I have (and love) stock springs with Koni's set to the lower perch (hose mod on rear springs)..........love it, rides like a caddy............handles almost like a corvette......almost........
Old Apr 24, 2006 | 10:24 AM
Bowtie Guy's Avatar
What he said.....
Old Apr 24, 2006 | 12:40 PM
Charging TA's Avatar
From what Ive read and heard, and at least in karting... lowering takes away traction, but the benefit is lowering the center of gravity a little.
Old Apr 24, 2006 | 05:40 PM
bearcatpride's Avatar
Any pics of your car?
Old Apr 26, 2006 | 11:05 AM
Breathtaker's Avatar
Thinking about getting new shocks over the horrible stock ones, but wanna keep the oem height, would the Bilstein HD's do the work? (it is not a daily driver, no drag racing whatsoever), good enough?
Old Apr 26, 2006 | 11:09 AM
Sam Strano's Avatar
LS1TECH Sponsor
I'd say that description fits HD's pretty well...... I won't say it's a solid recommendation from me because I won't do that without speaking to a person to find out other details. But from what I read here (which is only 3 lines of text), it seems to me that HD's would suit you pretty well.
__________________
Old Apr 26, 2006 | 01:07 PM
J. Brown's Avatar
I will go out into the parking lot right now a take one..............
Old Apr 26, 2006 | 01:15 PM
Sam,
I need to call you up someday to talk about suspension... right now I gotta get a few things such as a new clutch and etc... but basically Im having trouble deciding if I even can drop the car due to the fact that it bottoms out when getting out of my garage, otherwise I would like to lower the front just a bit and get a good daily driven and road-track rather than drag suspension setup. But like I said Ill call you someday, so if you see a European number that will probally be me
Old Apr 26, 2006 | 01:26 PM
J. Brown's Avatar
It measures to be 3/4" lower than stock front and back.
Old Apr 26, 2006 | 02:53 PM
dailydriver's Avatar
Sam, I don't have the Solo 2 rulebook handy. When people do the lower front perch Koni/remove rear isolator mod with stock springs and rear swaybar, are they still stock class legal?? Or is that considered altered pickup points?
