best shock for your $$$$$
Old Apr 25, 2006 | 01:26 PM
LS1rscamaro's Avatar
Default best shock for your $$$$$
any sudgetions? on the best route to go for shocks i dont have alot to spend but i need a good set of shocks. for the rear.
Old Apr 25, 2006 | 09:57 PM
98_1LE's Avatar
If you don't have a lot to spend, then look at the Bilstein HD. Sponsors or eBay are great places.
Old Apr 26, 2006 | 08:15 AM
chupr0kabra's Avatar
Are you lowered?
Do you plan to lower?
What are your goals with the car?
Are you looking for better handling or is straight line performance your only concern?
-Mike
Old Apr 26, 2006 | 10:55 AM
Wyckedcamaro's Avatar
take the money and use it for HOOKED ON PHONIXS with spelling words the way you do.
lol just kidding man.
I have KONI SA's the 4x4's but they were expensive.
Get BILSTEIN REVALVED HD's from Strano.
Those are good too!
Old Apr 26, 2006 | 11:12 AM
Sam Strano's Avatar
LS1TECH Sponsor
Like was mentioned earlier..... "bang for the buck" can mean a lot of different stuff. Scion's are good bang for the buck, if you are looking for a solid car that will last and get good mileage. A Corvette Z06 is good bang for the buck because you get supercar performance at under $70k. That price isn't cheap, but you get great bang for those bucks.
Have to define the "bang" you want. Nobody wants to overspend, so we all look for the best value. But $800 could offer you more value than $350......
__________________
Old Apr 26, 2006 | 12:08 PM
todddchi's Avatar
Well if the OP doesn't chime in I'd appreciate a recommendation for:
- 2000 Z28 Convertible
- Stock springs, staying that way
- Factory deCarbons (50k on them)
- 275 rubber on 17" Zo6 knock offs (heavy)
Really I'm looking for a quality OEM replacement shock that will perform at or above the factory shocks and struts as a uniform characteristic set.
- Same or better ride quality vs. handling compromise
- Good durability (50k or so)
- Reasonable cost (maybe $500 tops)
The car is absolutely a daily driver, and I have no complaints about the current handling, ride quality, or launch traction/hop behaviors, but I realize the stockers are getting to the end and I wouldn't mind an upgrade or at least making an intelligent decision.
I figure the SLP Bils are probably a pretty safe bet but I'd like to know, especially since it's a vert. In all honesty I'd buy a set of take-off factorys if I knew I could get the right ones.
Thanks.
Old Apr 26, 2006 | 12:14 PM
Thanks.
SLP Bilsteins are valved for the SLP springs. If you're running stock ride height with stock springs, you might be happy with a set of Bilstein HD's.
-Mike
Old Apr 26, 2006 | 12:23 PM
ws6formula98's Avatar
dam!! Last time I got some $15 autozona shocks, I should of wait untill I have some more money, it took me about 2 hours to change them.
