Wandering/bump steer
Old Apr 28, 2006 | 11:07 AM
keliente's Avatar
Default Wandering/bump steer
00 Z28, suspension - eibach prokit (front), stock springs rear, Bilstein HDs, 35mm front & 21mm rear hollow strano bars.
I love my car but I really hate how it follows the road...I have to pay really close attention to it on a bumpy road or it will take me right off of it - it follows the ruts in the road/bumps too easily.
Anything I can add to help that problem?
Old Apr 28, 2006 | 12:06 PM
BlackHawk T/A's Avatar
What tires are you using?
My problem was solved 75% after I put my Nittos on. I had the stock tires and they were getting pretty worn and the car drove like crap on uneven roads.
Old Apr 28, 2006 | 01:38 PM
jimmyblue's Avatar
Moderator
There is a bump steer kit out there, a bit pricey. I had
a bit more caster put onto the alignment when I had
the front suspension & K done and this seemed to help
it some. I think it's not really a bump-steer deal, just
a neutral setup that doesn't have a strong center /
straight-ahead bias. I've felt it track grooves while no
real suspension deflection (bump) was going on.
Old Apr 28, 2006 | 03:07 PM
BitViper's Avatar
Is this wahat your talking about
Baer Tracker Bump Steer Adjuster Kit
JEGS
