Back-Left tire squeeking..HELP
Old Apr 29, 2006 | 08:30 AM
LANDONZ's Avatar
Default Back-Left tire squeeking..HELP
Hey guys,
My girlfiend(Summer) on the board, is having alittle problem with her Camaro but I like to get it fixed for her..Her back left tire makes a little chirping noise soon as the tire starts to role. Now her dad went in and changed/Adjusted something in there about 3 months and now he wont do it again cause he says to live with it..BUT I cant..Anyone have any idea what he may have done in there..It has to do with the E-brake most likely.. Her e-brake doesnt work at all, and she has never used it?
Thanks
Landon
Old Apr 29, 2006 | 09:26 AM
98_1LE's Avatar
Sounds like it needs rear brake pads
Old Apr 29, 2006 | 10:21 AM
LANDONZ's Avatar
I know that seems to be the most logical thing..Ill try that and see if things change..I think I remember her saying she just had them changed..Ill check with her about it
Old Apr 30, 2006 | 07:32 PM
Mike 01WS6's Avatar
Sounds like he doesn't like you much either....
Old May 1, 2006 | 12:10 PM
ohsofast's Avatar
Sounds like he might have change the brakes, but all you need is to get anti squeal for the brakes. It is like 3 dollars at Advanced or Auto Zone. Just put it on your brake pads and you will be golden, no more noise.
Old May 1, 2006 | 05:22 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
It could possibly be U-Joint or Wheel Bearing also----if it is constant "Chirping" it won't be a brake pad--that would be a loudish grinding....
