Suspension Help
Old May 5, 2006 | 10:39 PM
408ls1's Avatar
Default Suspension Help
I Have A 408 Ls1 Camaro With Qa1s All Around Eibach Springs In Back Lcas Tq Arm Phb Lca Relocation And Subframes My Car Lifts The Front Wheel About Three Inches On Motor But When It Lifts The Front It Seems The Back Of The Car Lifts Too And When It Does It Breaks Loose I Put A Sphoon Tunnle Mount Tq Arm And Put The Lcas In The Lower Hole At The Same Time And I Think That Is When It Started The Pinion Angle Is Set On Neg 3 Deg What Do I Need To Try
Old May 6, 2006 | 02:49 AM
blown 346's Avatar
My buddy has his pinion angle at Neg 2. depending on how much wheel spin you are getting, you might even want to try 0.
