2002 z28 115.000 miles -shocks rear
The fronts are shocks, not struts.
AFA you vs. an install shop, look at here, then decide:
http://www.ls1howto.com/index.php?article=6
http://www.ls1howto.com/index.php?article=8
If you're only replacing shocks and keeping everything else, then just do the reverse of the install. For the rear, you don't have to do all of the trouble that the instructions put you through. just find the "flaps" that are sewn shut, cut the stitches, the fold up and remove the padding in order to reach the rear top shock moutning positions.
