TA / Axle Vibration Solved...Almost
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I got rid of most of the vibration that's plagued many of us with frame mounted TAs.
As many of you, I've changed my pinion angle dozens of times. Here's what I did the last time to make it work:
I removed the DS and measured the transmission output shaft = 5 degrees down from front to back.
I then installed the DS and measeured the the axle angle off of the bottom plate of the torque arm where it bolts to the axle. (If I do it again, I would measure the actual pinion angle)
I set the axle at +3.5 facing up towards the front of the car.
I now have less than 2 degrees defference between the 2.
Some people insist that the pinion needs to be 2 degrees down but I've read up alot on this and it applies to leaf spring set ups due to the flex on the front of the leaf on acceleration.
The 0 to -2 pinion angle should be relative to the crank centerline--not the ground. Measure the angle on the face of the crank pulley. Measure the pinion across the yoke and set it 0-2 down from the crank pulley.
