Torque arm question
Yes I would recommend a adjustable version since the vehicle is lowered. It will allow you to correct pinion angle for the best traction (which I am assuming is a concern). Some information on our item can be found at the link below, if you have any questions please ask and I will be glad to help.
http://www.umiperformance.com/2205.aspx
Thanks
Ryan
And as far as clearance here's an U.M.I. cross member mount TA.
They tuck up great. And Ryan builds one hell of a product line.
Hawk
Lee Spicher
lee@bmrfabrication.com
I am definatley willing to try again, I do not like flaming sponcers, and I will remove my prevous comments if you can make good on justifying your product as a quality part to me.
ok, well from the begining, I know I had posted this else were in here and on the old ls1.com but I think it has been archived. so here goes,
I installed your torque arm on the car at 7000 miles. before the install, the tranny was solid, no wobbles, and the rear end felt planted and tight, I heard zero, I mean zero drivetrain noise. also before the install, I checked my pinion angle and original torque arm lenght as a reference for new bmr unit. Removed the old stock unit. Finally the the adjustable bmr piece arrived from thunder racing in the nice red color. this was my first suspension mod, and pretty much my only mod besides lid and ram air and filter at the time. I did not even have a cat back at this time, so I heard everything. So, I got the new piece all adjusted to the proper lenght, bolted the new bushing into the tranny and installed the two bolts through the rear end as par the instructions. set the pinion angle to -2.5 degrees as par my stock measure ment, took a ride. sounds like pinion is howling. stick vibrates like hell on the tranny. hmm, maybe it is the angle, so I go to -3 degrees same, -2 degrees, same, after about 3-4 weeks of adjustments swearing and all around displeasure in my 350.00 purchase I call you guys up, after three to four calls, in a nut shell, the response I get is that is normal. I am not sure how sounding the the rear end is going to explode is normal. anyway I drained and inspected the rear end, changed the fluid, its fine, bought new stock bushing and shell, installed stocker, no issue. gave bmr one more chance, reinstalled, same issues, if you have any suggestions please let me know, it is almost like the unit is bent, or something, I do not know I have spent 3 years and about 10000 miles trying to figure it out, to no end. I have installed it 5 times and evertime after the removal it noise is gone. Tried new ujoints out put yoke and got drive shaft rebalanced(did not need it no charge) so, if you want to understand the noise I have, to give you an idea, it sounds like when my toyota truck toasted the rear end, but like I said the rear is fine, and I know this because the fluid has been changed everytime I removed the tq arm, I also inspected all the gears, plus the noise is gone after old arm is put back on.
my conclusion, the arm is either messed up, ie I got a trq arm built on May 6th, or the first day back from new years break, or the design its self is just substandard and not satisfactory to me
I have tried everything I mean .10 of degree adjustments in about all ranges from 1.5 to 4, nothing works, It is pretty bad when I can hear my driveline over my headers. Well Lee, let me know what you think. I would call you, but I really prefer either pm's or post here, I spent way to much time on hold last several times I called your company. Arm is in new condiction, minor nics near adjustment hiem joints and around the rear bolts from tightening. Car never sees rain and has about 21000 miles at the time of this post. Thanks for your help.
I went for a ride the other day after putting it on. I floored it from 3,500rpms in 1st and I thought something was wrong because it was really difficult to break the tires loose. Then I was like, oh you moron you put the t/a on, that's why!! Like I said, I'm dying to get to the track.
Thanks
Lee Spicher
Lee @bmrfabrication.com
(813)986-9302
