heater hose mod
Old May 22, 2006 | 09:39 PM
Artic98T/A's Avatar
Default heater hose mod
I'm just checkin in here to get an idea on this setup for my rear springs. I have ordered Koni SA's from Strano and they should be in this week sometime and I would like to get my stockers ready to go back in (currently G2...too low). So far from my searches it seems like 5/8" Diameter heater hose and force over the top of the coil. I read I'd need about 18" i'm guessing 9" for each side. Anybody who has done this mod and has any input or advice I would greatly appreciate it. Thanks.
Old May 23, 2006 | 10:51 AM
Bowtie Guy's Avatar
Just slide the hose over the top of the coil as far as it will go....a little silicone lube will help.
Old May 23, 2006 | 10:57 AM
ls1mongrel's Avatar
Its easy, just use some lube like syggested above !
Old May 23, 2006 | 11:13 AM
Artic98T/A's Avatar
Thanks for the replies, I'm going to give it try tomorrow night and see how it goes.
Old May 23, 2006 | 04:18 PM
Artic98T/A's Avatar
fixed my poor unit of measure mistake... I went out and measured the circumfrence of the spring so I could buy the heater hose and its 18” per spring, to wrap all the way around the top coil.
Old May 23, 2006 | 04:53 PM
zrater's Avatar
What The Hell Does This Do.. Thanks
Old May 23, 2006 | 05:20 PM
blue01ta's Avatar
It will lower the rear of the car about 1/2"-1". Remove the isolators and put the hose on the springs to keep from having metal-metal contact.
Old May 23, 2006 | 05:23 PM
Mcduffys's Avatar
It gets ride of the huge rubber stop that sits above the sping and levels the rear off about 1/2 inch or so. Its a simple mod and levels the car out a bit on a stock or near stock suspension.
Old May 23, 2006 | 05:57 PM
916LS1's Avatar
So this will LOWER the rear end? I have the prokit springs with stock shocks and a big fat speaker box in the trunk. My rear end sits about a half inch lower than the front. If I were to thread my rear coils with heater hose, won't that raise the suspension???
Old May 23, 2006 | 07:03 PM
heymoej's Avatar
yes if you leave the rubber isolaters on with the hose!!!!! but the hose is used in place of the rubber isolater & since the hose is thinner the rear sits lower!
