Suspension, powersteering, LS1 brakes on '93 T/A 111k miles
Background: '93 T/A with 111k miles on it. Just purchased a LS1 brake upgrade kit from Whistler and want to make sure I don't need to replace anything else in the steering/suspension before I put it all on and pay for an alignment. The car is running original shocks/springs and I think a ball joint _may_ have been replaced. What should I inspect? I'm primarily wondering about ball joints, bushings, shocks, etc.
One more thing--for a while my steering was hard to turn at idle... Giving it a little gas helps restore power to the steering... Power steering fluid was drained and replaced when I did my heads prior to the problem starting to occur. It's been better lately (2 months later) after slightly topping off fluid. The pump did drop about 18" onto the concrete when I was taking it out. Do you think I may have just insufficiently bled the line on reassembly or is this the sign of a failing power steering pump and/or rack and pinion assembly.
Also, do I need to buy LS1 caliper mounting bolts for the upgrade or can I reuse the original LT1 bolts?
Thanks,
FraggleRock
Thanks,
FraggleRock
Originally Posted by FraggleRock
My steering is hard to turn at idle... Giving it a little gas helps restore power to the steering... Power steering fluid was drained and replaced when I did my heads prior to the problem starting to occur. It's been better lately (2 months later) after slightly topping off fluid. The pump did drop about 18" onto the concrete when I was taking it out. Do you think I may have just insufficiently bled the line on reassembly or is this the sign of a failing power steering pump and/or rack and pinion assembly.
