Gone Bad Shock or Spring?????
Old May 26, 2006 | 06:10 PM
2000Z28M6's Avatar
Default Gone Bad Shock or Spring?????
About a month ago I hit a curb really bad and it broke the front wheel. Now the car sits 1/2in lower on the front side. I'm thinking the shock or spring is not holding up. So which would more likely have gone bad from a bad impact.?? The Koni or the Hypercoil? I need to replace either to fix it... So should I try new springs? or just replace the shock?
Old May 26, 2006 | 11:27 PM
trackbird's Avatar
I vote for a bent control arm. Springs are tempered. They can sag, but I doubt that hitting a curb would cause it. Same for shocks. I'm guessing that you bent the lower control arm (not unusual).
Old May 27, 2006 | 05:22 AM
2000Z28M6's Avatar
trackbird, could you explain to me how a bent control arm would cause a 1/2in drop? I just dont understand the front suspension that much...
Old May 27, 2006 | 12:14 PM
trackbird's Avatar
The shocks are mounted to the front control arms. The springs are mounted to the shocks. That's what supports the vehicle. If you shorten the springs (and keep the rate the same, I'm not getting into that discussion right now), you lower the car. If you were to bend the control arm between the lower shock mount (on the control arm) and the balljoint, the ride height could be changed. I suspect you'll find that the control arm is bent at the shock mount or between the mount and the balljoint. I'd think you would be able to see a bend that could generate a 1/2" difference in ride height, but, how visible it is depends on lots of things.
I'd start by looking at both lower arms and trying to see if one looks "kinked" or bent.
Did that help?
Old May 27, 2006 | 12:28 PM
2000Z28M6's Avatar
ok so the front control arms are the ones at the base right? cuz the top are the A arms.? ANd Ive looked down in there for any sort of bend but nothing looks visibly bent.
Althought you are probably correct. Well I guess I'm ordering a front control arm. Does it include the balljoint.??
Appreciate the feedback trackbird.
Old Jun 2, 2006 | 05:22 PM
2000Z28M6's Avatar
do you think the k memeber would of kinked before the control arm????????
Cuz the K member kinda looks like it has a lil kink.
Old Jun 2, 2006 | 09:34 PM
trackbird's Avatar
Depending on how you hit, and how hard, anything could be bent. The spindles are known for bending in an impact, the lower A arm could bend, you could bend the K-member. It's hard to diagnose from where I'm sitting, but I'm glad to offer any guidance that I can.
Old Jun 2, 2006 | 10:34 PM
DONAIMIAN's Avatar
FWIW I have a stock front control arm laying around that I just want to get out of the garage. What side is it?
Old Jun 3, 2006 | 12:53 PM
2000Z28M6's Avatar
Don its the drivers side...........Is the K member a bitch to replace??? It kinda looks like it?
In other words is it sumone can do in the garage,?
Old Jun 3, 2006 | 05:55 PM
DONAIMIAN's Avatar
You can do it in your garage, but how long it takes depends on who you have to help. I can be all day job.
