Wheel bearings
Old May 27, 2006 | 07:12 PM
RYDER661's Avatar
Default Wheel bearings
how do you know if your wheel bearings are messed up? does it make like woooooo woooooo sound over and over this noise only comes when i accelerate?
Old May 27, 2006 | 08:11 PM
Wyoming T/A's Avatar
they will usually make noise all time ,swaying car side to side will usually change noise if it is wheel bearing
Old Jun 14, 2006 | 12:43 PM
157mpHourly's Avatar
Yes, I have noticed my car doing this as well, but never could figure out what it is.
Are these easy to install???
Old Jun 15, 2006 | 02:07 PM
lo_jack's Avatar
Fronts are pretty easy, rears aren't as easy but it's not rocketry.
Fronts are sealed - replace entire hub. Remove wheel, caliper, rotor, and unplug ABS sensor. 4 bolts from back hold hub to spindle, remove those and apply PB Blaster like its going out of style. Boom.
