Help steering play problem
Old Jun 10, 2006 | 12:24 PM
1blackz28's Avatar
Default Help steering play problem
Ok I had a belt break in one of my front tires that caused the front to shake bad. I had to drive it like that for two days. After I got the new tire put on I now have play in my steering. When the tires are dead straight you can turn the wheel to the 11 and 1 o'clock position with no movement of the tires. I did a search and found that the rag joint may be to blame but then one guy with a 98 and up said the ls1 cars dont have the rag joint. Any Ideas.
Old Jun 10, 2006 | 08:24 PM
PunishedU's Avatar
Have someone sit inside the car and move the steering wheel just within it's play. Then look under the hood while he is doing it. There is a joing in the steering shaft right by the drivers side header. My car had this same problem and I could see that the top of the shaft was moving, but below the joint wasn't. It was called a rag joing and I had it replaced. A million times better now. Hope that helps.
Old Jun 10, 2006 | 09:18 PM
keliente's Avatar
LS1s dont have rag joints like an LT1 does.
An LS1 just has a little u-joint. It is possible the joint is worn, or the steering shaft is not on tight.
Old Jun 10, 2006 | 11:54 PM
PunishedU's Avatar
See, I learn learn something new on this site every day.
Old Jun 12, 2006 | 07:37 PM
1blackz28's Avatar
Cool thanks for the replys guys anyone elese with this problem
Old Jun 12, 2006 | 09:01 PM
xaon's Avatar
my steering wheel also moves slightly without moving the tires... It started doing it after i changed out my k-member & a-arms... I have not really investigated any further to figure it out though.
