Wtf No Brakes
i put a 230/236 565/565 112 LSA cam in and ever since then i havent had any brakes. The pedal goes to the floor durring hard braking and wont even hold the car back to do a brake touqe. I have replaced the master cylinder and bleed the brakes nothing. is this a tuning issue cause i have LT1 Edit and tune the car myself. It also pulls 10 inches of vacum is that enough to help assist power brakes, i thought if it wasnt then the pedal would be hard?
please help.....
please help.....
It doesn't sound like a vacuum/booster problem to me. You are right, it would be a hard pedal then. Sounds like a master cylinder/air in system problem. I don't know how changing a cam would affect that though...unless you punctured or loosened one of your lines accidentally.
