Brake crises
Old Jun 14, 2006 | 12:52 PM
SS4Luck's Avatar
Default Brake crises
So im driving home from school and out of no where my brake pads rip themselves apart and in a matter of 4 or 5 seconds my rotors were shot... SO the car is sitting in the driveway with no brakes and me frustrated to beat hell. I need new pads and rotors and i would like to upgrade as much as possible but i only have about $400.... which isnt too much i know
i was looking and ws6store has a set (front & rear) of drilled and slotted rotors
for like $170 and they also have various other rotors from other companies too...
i was wondering if anyone had experiance with the cheaper ws6store brakes as i would like to have a little money for the start of summer...
also i was going to get the green stuff brake pads ive heard those are pretty good too....
any suggestions would be grately appreciated as my car is no drivable and i want to get back on the road...
lol sorry for the length of the post, but its like ****! thanks guys
Old Jun 14, 2006 | 01:58 PM
99FormulaM6's Avatar
i just looked at them and i would just got ahead and get them. they have a 90 day warranty against cracking and warping, and ive never heard anything bad about them
Old Jun 14, 2006 | 02:04 PM
CW00BlackTA's Avatar
Autozone rotors are favored by many as they are inexpensive and durable (with a guarantee). Add your favorite brake pad and you're good to go. This combo should suit you fine unless you are into road racing.
Old Jun 14, 2006 | 02:05 PM
Carlos01SS's Avatar
Know that drilled/slotted rotors are only for looks, and if you want better stopping power you can get a good quality set of blank rotors from AutoZone, and with a great set of pads you'll be stopping better than before.
Blank rotors+great pads will stop better than drilled/slotted rotors+great pads due to more rotor surface for the brake pads to grab on to.
Old Jun 14, 2006 | 02:43 PM
do autozone rotors come zinc plated to resist rust?
Old Jun 14, 2006 | 02:58 PM
SS4Luck's Avatar
yea i like the looked of slotted drilled... i no blanks do work better, but i doubt I'll ever need the difference in stopping power... ill pry order those rotors tonight.. ill keep you updated on how they perform
Old Jun 14, 2006 | 04:35 PM
Carlos01SS's Avatar
I have no idea unfortunately.
Old Jun 14, 2006 | 05:02 PM
damn. someone should call and find out
Old Jun 14, 2006 | 07:07 PM
mrhzk35404's Avatar
I don't think they do
Old Jun 14, 2006 | 09:51 PM
joshp14's Avatar
I have the Autozone blanks on my TA and no they dont resist rust. I should have painted them after I bought them.
Old Jun 14, 2006 | 09:55 PM
how could you paint them? if you paint the rotor the pads would rub it off...
Old Jun 14, 2006 | 10:22 PM
spy2520's Avatar
he probably means around the vane area and the hat where the pads will never touch...
Old Jun 14, 2006 | 10:26 PM
im worried about the rotor surface...not the drum part
Old Jun 14, 2006 | 11:09 PM
joshp14's Avatar
LoL...the rotor surface where the pads contact will not rust...its the hats you should worry about, cosmetic wise anyway.
Old Jun 14, 2006 | 11:26 PM
ok, well, the stock rotor surface does rust. and most aftermarket rotors come zinc plated to prevent that. which is why i was unsure if the autozone rotors would prevent the rust.
Old Jun 15, 2006 | 12:29 AM
spy2520's Avatar
the rust on the face of the rotor is a non-issue because if you hit the brakes ABRA CADABRA rust is gone...
Old Jun 15, 2006 | 06:13 AM
well yes, i know that...but who wants rusty rotors?
Old Jun 15, 2006 | 06:59 AM
Dans2000SS's Avatar
When they plate the rotors they do the entire rotor. After the pads are broke in, the plating on the friction surface of the rotor is gone and they will flash rust if they get wet. But as soon as you drive the car and hit the brake the rust gets wiped away. The plating is only intended for the non friction areas. Mine were nickel plated and the the manufacturer told me to do the break in proceedure after the plating is worn through so the pads can bed properly. Hope this helps.
Old Jun 15, 2006 | 08:09 AM
so youre saying, even if i go and buy zinc plated rotors, the rotor surface will rust anyway?
Old Jun 15, 2006 | 09:43 AM
Dal1as's Avatar
Yes. Just get the Autozone blanks, a bottle of high temp paint, and a set of good pads (I like the Raybestos quiet stop ceramic)
Make sure you torque the wheels correctly and you should be fine.
