Difference from T/A to WS6?
Old Jun 17, 2006 | 10:57 AM
ZROCWS6's Avatar
Default Difference from T/A to WS6?
Is there that big of a difference between the suspension on a T/A to a WS6?
Old Jun 17, 2006 | 01:23 PM
Arachnotron's Avatar
There's not a really big difference.
https://ls1tech.com/forums/showpost....83&postcount=5
Old Jun 17, 2006 | 03:51 PM
BlackHawk T/A's Avatar
Ram air package (raised air box, ram air hood)
17x9 wheel/tire combo
3.23 gears
Some suspension parts
Old Jun 17, 2006 | 03:52 PM
ZROCWS6's Avatar
Yeah I know the appearance mods that they came with I am wanting to know the differences between the two suspensions. How much better does one handle than the other?
Old Jun 17, 2006 | 07:56 PM
DONAIMIAN's Avatar
you get a 32mm swaybar, and thats pretty much it. With the firehawk, you get more options.
Old Jun 18, 2006 | 10:28 AM
97LT1WS6's Avatar
Suspension-wize, all four shocks are larger, front springs are 1" lower with increased rate, the 32mm front bar is larger the 29mm TA. The rear 21mm bar was are rare special WS6 option that had to be special ordered. I believe thats it.
Old Jun 18, 2006 | 12:13 PM
DONAIMIAN's Avatar
Same shocks as the regular T/A, dont know where you got that information from. And never heard the term "larger shocks" before either. They also share the same spring part number, and the regular T/A has a 30mm bar upfront. The last time you could ge the 21mm bar from the factory was on a 93 1LE, every car after that came with a 19mm bar in the rear.
Old Jun 18, 2006 | 06:48 PM
lsx24's Avatar
You gotta be talking bout two different cars!
Old Jun 18, 2006 | 08:48 PM
97LT1WS6's Avatar
Thanks for the correction on the stock front sway bar mm. I forgot what the standard TA size was. However, my WS6 shocks are muct larger in diameter than my TA shocks. There's different part numbers on the Decarbon shocks for WS6.
Old Jun 18, 2006 | 08:52 PM
slow's Avatar
98-early 2000 cars actually have different shocks, (still decarbons, but different) where midway through 2000 they watered down the WS6 "suspension" package to just swaybars.
Ryan
