adjustable STB?
Old Jun 18, 2006 | 01:56 AM
94z28L's Avatar
Default adjustable STB?
what are the advantages to an adjustable strut tower brace over the standard non adjustable version? my car will be primarily set up for drag racing and a torque arm would be next on the list if i had like $200 more, just looking to eliminate some chassis flex.
thanks,
Mike
Old Jun 18, 2006 | 02:02 AM
Killer_Bluebird's Avatar
STB will not really help you in Drag racing aplication. It helps mostly on Road Racing and Auto X, specially if you are using aftermarket shocks with stiffer front springs, although it still helps a bit with the stock setup.
Old Jun 18, 2006 | 02:42 AM
94z28L's Avatar
alright thanks, is there really any kinda advantage to the adjustable one tho over the non?
Old Jun 18, 2006 | 02:48 AM
Krab's Avatar
I don't believe there are any adjustable shock tower braces (STB's), now pan hard rods and lower control arms is another story.
Old Jun 18, 2006 | 02:52 AM
94z28L's Avatar
check spohn, they make one, its an option that costs more
Old Jun 18, 2006 | 02:58 AM
Krab's Avatar
I stand corrected. Either way, if it were my car, I wouldn't put it on. Do a search on the subject and you'll find a few good reads about just how functional an STB is. It's basically dead weight on the nose of your car.
Old Jun 18, 2006 | 03:09 AM
94z28L's Avatar
alright thanks, ill put the money towards something more useful
Old Jun 18, 2006 | 06:03 AM
CashMoney's Avatar
sway bars are where it is at for road racing.. your car will feel like it is on rails..
Old Jul 9, 2006 | 10:57 PM
slow67's Avatar
Gingervitis Addict
If you wallow out your bolt holes on your struts (for alignment purposes) I could see the advantage of an adjustable one.....
Old Jul 9, 2006 | 11:09 PM
DONAIMIAN's Avatar
Our alignment is determined by the position of the control arms in their mounting locations. Or front suspension is differnt than a mustang.
I see an adjusable shock tower mount as a waste. If you preload it all you will do is push the strut towers furthur apart and thats just gona throw the alignment off.
Old Jul 10, 2006 | 05:19 AM
Foxxtron's Avatar
STB=HTLO+DWN
Translation: A strut tower brace is a handle to lean on and a dead weight on the nose. Will do nothing to alter the geometry of the front end, nor prevent anything that isn't occuring, which includes placebo effects. Most of the loads are going through the K-member, not the shock towers.
Old Jul 10, 2006 | 03:14 PM
dailydriver's Avatar
It might help keep the twist down if you are pulling the wheels on launch in an un-caged drag car on slicks to a < 1.5 60'. Other than that, it is what Foxxtron said. Besides if you have a drag car like that, you SHOULD have a totally tied-in cage in the thing!!
