abs light and brake light
Old Jun 18, 2006 | 09:58 AM
monkey11's Avatar
Default abs light and brake light
just trying to find the wire that you ground to get the lights to go away. i have a 9" with the sjm brake delete/line lock kit, now just need the light to go away! bye the way it works great
Old Jun 18, 2006 | 12:51 PM
bad6as's Avatar
im prety sure im geting a 9" more info on that kit?
could the light be turned out threw a tune?
Old Jun 18, 2006 | 03:32 PM
monkey11's Avatar
well i got the kit because i have abs but no traction con. which is a 3 ch. that means the sensor is on the diff. but with a ford 9" its a different setup, no spot for the sensor! so for the 200$$ i ordered the kit which replaces the abs block and comes with a line lock. lines are pre formed and came with a flaretool and fittings. it seems difficult but its pretty simple really. i love this kit and as for driving with no abs it drives fine( you really only use abs when your about to crash) look up sjm they a sponsor on here
Old Jun 18, 2006 | 03:34 PM
bad6as's Avatar
mines a 3ch as well.
but is there a way for the light no to be on?
Old Jun 18, 2006 | 07:12 PM
monkey11's Avatar
there is but i dont remember how and not sure if you can get it off by a tune because there is a seperate computer for abs . people post up some one knows what im talking about??
Old Jun 20, 2006 | 09:56 PM
monkey11's Avatar
some one must know the answer???
Old Jun 21, 2006 | 12:14 AM
Brasshead's Avatar
I had my SJM ABS delete kit installed along with my Strange 12-bolt running a spool and 3.73 gears. This setup eliminated my ABS/ASR anyway (I had a 4 channel system) so the kit allowed me to clean up the engine bay at the same time. As for the dash lights, I had every bulb associated with my ABS/ASR removal lit so I ended up taking the dash out and taping over the LED bulbs with back electrical tape. I now have no hint of warning lights showing on my dash. On the LS1 cars the only ways to kill the lights is to tape over them or pull out the LED’s. You can not tune them out or ground them out the way the LT1 cars could from what I heard from SJM.
