BMR Xtreme Torque Arm
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
I'm buying a used BMR Xtreme Torque Arm used from a member. I was wondering if this setup must be welded and if it must be welded woul I run into issues re-welding it to my setup? Also if it must be welded is the portion that must be welded also Chrome moly? Is there a special way chrome moly must be welded or is welding it the same as welding any other material?
how are you going to weld it? if you OA weld it, then the procedure is the same, TIG is the same as OA(as far as the rod choice, er505, er502, er80s-b2, or er90s-b3), and MIG you need er505 or er502 wire
I would not take it to joe blows exhaust shop, i would take it to a certified weldor since it is a pretty critical part of the rear ends alignment characteristics.
where are you located at?
