new rotor needed?
Old Jun 19, 2006 | 05:29 PM
goodrich969's Avatar
Default new rotor needed?
i was tryin to put my lug nuts back on and 2 of the 5 were stripped and wouldnt catch the thread very well at all... The other 3 are perfect but the 2 are jus not catching.. What should i do? Thanks
Old Jun 19, 2006 | 06:41 PM
1badragtop's Avatar
sounds like either new lug nuts needed or wheel studs, or both.
Old Jun 19, 2006 | 11:20 PM
how much do wheel studs usually go for?
Old Jun 20, 2006 | 08:46 AM
i got 2 quotes... 60 bucks and 80 bucks... can anyone tell me how to put 2 new wheel studs in?
Old Jun 20, 2006 | 08:50 AM
so basically all i do is take the caliper off and what else off? And jus hammer then out then hammer the new ones in?
Old Jun 20, 2006 | 05:03 PM
1badragtop's Avatar
wheel studs should only be like $5-$10 for each. remove the rotor to expose the wheel hub, then hammer out the stud. the wheel stud can be drawn in by a lug nut or hammered in. the rear will require axle shaft removal.
