diff between 3 channel and 4 channel ABS?
Choose whichever rear-end you prefer. Unless ABS is that important for you...delete it. Depending on what you choose, non-ABS rear-ends are less expensive AND will be less problematic in the future. You no longer have to deal with HAVING to run equal diameter tires so ABS can be utilized, issues at the track w/ABS acting up when you don't want it to... and no more trouble-shooting issues of "why is my ABS not working correctly".
We can help you with your rear-end purchase if you decide on either a Strange 12 bolt or a Strange Dana.
We also manufacture an ABS delete kit which will drop ~15 lbs from your front end while adding a proportioning valve which enables you to fine-tune your brake bias. This is especiallly important if you're changing to different tires, rotors/pads etc. You'll also clean up your engine bay quite a bit and increase thermal transfer.
Our kits come ready for most line lock solenoids if you already own one, or we can include one with a complete electrical kit w/LED indicators, master switch and control switch with assessories in the kit at minimal costs...down to even the rubber grommet for running the wires through the firewall.
