Koni SA rear
Old Jun 20, 2006 | 01:10 PM
kokki's Avatar
Default Koni SA rear
I have some problems with rear shocks.. I haven't installed those yet, but I'm tryring to find out how to adjust the shock .. I have the ****, and Koni's website talks about the button... you should hold down that when you adjust, but these Koni's don't have that.. and I do not get any click when I turn the ****.. and I turned some rounds and did not get any "maxed" out or so.. And now I'm very confused how stiff or soft is that.. is there any way to find out?
Old Jun 20, 2006 | 01:52 PM
coolformula's Avatar
Well if its 4gen rears it comes with a **** that shows which way is tighten or soften......
3rd gens rears are different.
I don't know which ones you have.
Old Jun 20, 2006 | 01:53 PM
Sam Strano's Avatar
LS1TECH Sponsor
I responded to your PM (which was identical to this message). There is nothing wrong with your shocks. Install them on the car. There is no button on yours, there are no clicks, and they aren't maxing out because they aren't installed and you aren't turning the adjuster, but the entire shock rod.
__________________
Old Jun 20, 2006 | 03:02 PM
kokki's Avatar
When I have installed, is there some stop when the shock is in the softest or the stiffest position?
Old Jun 20, 2006 | 03:05 PM
dailydriver's Avatar
YES, there is a positive stop on both ends of adjustment. I forgot how many turns of total adjustment though, Sam, Anyone??
Old Jun 20, 2006 | 03:54 PM
BAD99TA's Avatar
After I put mine on I turned them all the way down and then all the way up. 2 & 1/2 turns until they are maxed out.
Old Jun 28, 2006 | 07:50 PM
kokki's Avatar
Default Koni SA front
Do you adjust front shocks before installation?
Old Jun 28, 2006 | 10:30 PM
always faster's Avatar
These are the basic settings that Sam Strano told me to do before installing them:
"-Set fronts all the way to full stiff (+) then back off 4-5 full sweeps of the adjuster across that slot.
-Rears. Set full soft, then up 1/4-1/2 turn"
After that just try to find what suit your needs best
Old Jun 29, 2006 | 12:13 AM
chupr0kabra's Avatar
You're probably better off adjusting them while mounted, just so things don't get out of adjustment while you wrangle them into place. This means you'll have to put a little forethought into how you mount them. Perhaps making sure the adjustment windows face out, toward the wheel, so you don't have to try to reach around the shock and/or wrestle with them.
-Mike
Old Jun 29, 2006 | 08:46 AM
BAD99TA's Avatar
I was playing around with my shocks before installation to get an idea how to adjust them once they are on the car. I ended up adjusting them to full then adjusting them completely to soft just to get the feel for the adjustment settings. For the final adjustment prior to putting them on I turned them to the softest setting (-) then I adjusted them 5 sweeps (+) towards stiff then installed them. I haven't touched them since. I figure there's nothing wrong with that and I can always adjust them at a latter time. Next time I adjust them I'm probably going to move them 1-2 sweeps (+) towards stiff.
