Did you get a road force balance when you balanced the wheels & Tires? If not, then I highly suggest you do so. What a road force balance offers over a regular balance is that a roller is placed against the wheel/tire to simulate road force. This will tell if the tire deflects improperly or has some other defect which could cause a vibration that a regular balance wont catch or premature failure. This may also better detect an out-of-round condition in the wheel/tire. Also, how much weight is on the rims? If it looks like more than a small amount, then the heavy part of the wheel might be lined up with the heavy part of the tire. In which case, the affected wheel/tire will have to have the tire roated 180* in respect to the wheel and rebalanced.
If you want to save money and are able to, swap to another wheel/tire package. If the vibration goes away, then the issue is with the wheel/tire package. If the vibration remains (an you know the alternate wheel/tire package is properly balanced), then the drive shaft may be out of balance (less likely scenario). If neither of those fixes the vibration, then the pinion angle could be off. Before getting the driveshaft balanced, check the pinion angle.
