HELP!!! Installing hal shocks
Old Mar 16, 2002 | 01:02 PM
minty's Avatar
Default Re: HELP!!! Installing hal shocks
if you want to go to stock ride height, its about 9 inches when you compress them....actually, 9 inches is just a TAD lower than stock ride height.....
Old Mar 16, 2002 | 01:10 PM
highgmc's Avatar
9 inche from where? from the bottom of the spring OR jam nut to the very bottom of the shock?
THANKS!!!
Old Mar 16, 2002 | 10:31 PM
minty's Avatar
its 9 inches from the bottom part of the shock that is bolted in, but you have to make sure that you hold it at the same angle as when it bolts on to make sure the measuring is accurate....
Old Mar 17, 2002 | 12:12 AM
highgmc's Avatar
Default HELP!!! Installing hal shocks
I am installing Hal front shocks and need to know a measurement from the jam nut to the front shock. Any tips and information will be greatly appreciated!!!
