Any way to delete ASR?
My Dads new 2002 Z came with Traction control,
and he hates it. And I wanna put my 2000
rear with non Asr in his car. Because im
getting a 12 bolt. Can this be done?
That's why there's a switch to turn it off. If he doesn't like the hassle, get a reversal module from someone like SLP. Easier than a rear end swap.
Coal Mining Director
It probaby can be done but you'll have to figure out (reprogram and wiring harness) how to set up a 3 channel abs brake with a 4 channel harness. You have a reluctor wheel on the ring gear (1 elec plug) and he has a reluctor wheel at each wheel (2 elec plugs on the back)...probably a pain to reharness and reprogram.
spiesscj
The reason I want to put my rear in his car is.
I have an Auburn pro posi with 3:73's in mine.And since Im getting the 12 bolt he could use it.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MechMan:
<strong>spiesscj
I have an Auburn pro posi with 3:73's in mine.And since Im getting the 12 bolt he could use it.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Makes sense. Still, onfire makes some good points I hadn't even considered, and dare I raise the warranty spectre.
<strong>spiesscj
Final post since you want it locked. If you try to install your rear "as is" in his car to delete the traction control feature it will be a pain as in my first post. If he want to keep 4 channel traction control it will be easy since you can put his axles in your rear.
