Help with ABS Brakes
Old Apr 11, 2002 | 07:00 AM
Billiumss's Avatar
Default Help with ABS Brakes
A few days ago, the wife and I were out and about with her car, 94 Pontiac Grand Prix SE 3.1L Auto
We went to the gas station to gas up and when I turned the car back on, the ABS light AND the parking brake light came on and stayed on.
I turned the car off to maybe reset the system, no luck. Drove the car home, drove fine, brakes fine, (for what they are).
When I got home, I disconnected the battery to reset everything. Waited 10 minutes, hooked it back up and still, both lights are still on. I even checked the brake fluid level too and that was fine.
This is the first time I have ever had any problems with this car.
I tried to do the paper clip trick, but the for some reason it wouldn't work, plus the pins aren't in the normal position as the would be on most GM cars. It's not OBDII cause it has 12 holes instead of 16 like 1996 and later cars.
I have a feeling that I'm going to have to sink some money into this car. So if any of you have any idea's, lets here them...
Bill
<small>[ April 11, 2002, 07:04 AM: Message edited by: Billiumss ]</small>
Old Apr 11, 2002 | 06:51 PM
2000 Camaro SS's Avatar
Default Re: Help with ABS Brakes
My 1999 Camaro did that the dealership had to replace a chip thingy or supthin. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I never knew what it was but they fixed it. I guess some car justr do that.
