Help! Front end noise
Old May 16, 2002 | 11:13 AM
Zatlanta's Avatar
Default Help! Front end noise
I have got a noise thats driving me crazy!
-Its comming from the front, a dampened banging that occurs when I hit a hole in the road.
-Its even worse when its warmed up.
-No noticable performance or handling problem.
-More noticable at low speed.
-The shocks,springs,swaybar & bushings/endlinks have all been replaced. Thats when the
noise started, but I have had it checked out and reassembled with no success.
-I'm guessing somthing is loose and banging the engine compartment or body underside... but
cannot find it.
I'm desparate.. any ideas??????
Maybe I should get a wedge of some type and put it in different areas to narrow my search.
<small>[ May 16, 2002, 11:14 AM: Message edited by: Zatlanta ]</small>
Old May 23, 2002 | 12:42 AM
zombiedude's Avatar
Default Re: Help! Front end noise
Just a thought. Maybe a spring not seated right? Just a shot.
Old May 23, 2002 | 08:44 PM
NoGo's Avatar
Did you have the car lowered or anything. Or is it bone stock?
Old May 24, 2002 | 06:29 AM
Zatlanta's Avatar
It makes sense (I guess) I now have stiffer springs/shocks, so everything under the hood ect is subject to more shock... so I guess I have to dampen all possible areas. I'm looking at the air lines/wheel well area now..
Isn't there anyone who has had to troubleshoot noises relating to shock movement against the body? What did you dampen?
