Suspension Pro's Help...Proper Tq arm adjustment
Who can tell me and half a million other people on here what the correct way to set the pinion angle is??? There are 2 links below claiming to be the correct way to get the -2* but my question is which is right? Which is wrong? I have tried both ways on the street and can not tell any difference between the 2. I guess the real test will be my 60ft times but I would love to know what direction to lean towards. Thanks in advance
http://www.streetissuecustoms.com/pinionangle.html
http://www.go-fast.org/z28/pinionangle.html
Originally Posted by SLowETz
They're both right.
The 2 I listed are not the same, totally different.
As per instructions from SPOHN and in the 2nd link, u use the driveshat vs. rear pinion. The top link says using the driveshat vs rear pinion is wrong that u use transmission shaft vs. rear pinion.....When I do the 2 methods my rear is way different from the other.
In link one, my trans. sits down -6* so to get the desired -2* pinion angle my rearend has to point up +4*
2nd link using the ds vs. rear my rear points down -1*.
From what I have gathered the rear pointing down is correct....but my issue is that when I have it set to the claimed -2* w/rear pointing down, my shifter will get very hot to the touch. When set at the claimed -2* w/rear up my shifter has no heat in it at all. This makes me think that w/ rear down is putting trans in a bind causing the shifter to heat up.....
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I used my tranny output shaft and pinion angles to correct a vibration I had. So, I used the first method. In order to set it up correctly so you don't have the chance of having any high speed vibration you need your pinion to be at the same angle as your tranny output shaft.
my rear end is pointing up at the same angle as my motor/tranny is pointing down.
what you are trying to do is get the differnces in angular velocities from a single cardon joint (u joint) to cancel each other out. The u joints in your driveshaft are installed 90 degrees out from each other. If you don't have your tranny output shaft and pinion angles the same your u joints angular velocities will not be canceling each other out causing your driveline to bind. The more the angles are off, the more driveline binding you will have.
