what do i need?
Old Jun 13, 2002 | 04:34 PM
prockbp's Avatar
Default Re: what do i need?
the only other thing you really need is an adjustable panhard bar
Old Jun 13, 2002 | 07:13 PM
DARK AGE 53's Avatar
As prockbp has said you'll need an adjustable panhard, the STB and SFC ( bolt on kind ) are worth installing.
The rear is quite easy but the front's are a pain in the *** ( removing the springs from struts ), if I was to do it again I'd remove the front ones then take them to a shop just to have them install the new front springs. If you do it yourself you'll need a front spring compressor, for the most part the do-it yourself compressors are junk.
Good luck and be careful.
Al
<small>[ June 13, 2002, 07:14 PM: Message edited by: DARK AGE 53 ]</small>
Old Jun 14, 2002 | 12:49 AM
hizlarpTA's Avatar
Default what do i need?
i want to get the eibach pro kit but do i need other things to make this work like a strut tower bracer and sub frame connectors or can i just put it on
also how long does it take to install (i have a lift)
