When to change rotors/pads?
I had a set of Powerslot rotors and Durastop pads installed about 12k miles ago. The brakes now feel somewhat less than confidence inspiring. How can I determine what if anything needs replacing? The rotors look OK but I was wondering if there is some measurement I should go by to tell if the rotors and/or pads are worn out?
Thanks!
Rob
Thanks!
Rob
Re: When to change rotors/pads?
having your brake fluid flushed/filled/bleed once every 6 months will work wonders
if you want to pull the calipers off and take a look at the pads... just look for 'even wear' on the pads.. they shouldn't be sloped(tapered)...
pulling the calipers is an easy job:
http://installuniversity.com/install...ds_mwarren.htm
<small>[ June 20, 2002, 05:18 PM: Message edited by: prockbp ]</small>
