28x11.5x15 et drags question please read
will these tires fit on a 99-newer camaro. If so, what needs to be done to get them to fit? these are mounted on a 15x10 pro star rim with a 7.5 backspacing.
Thanks
Thanks
IVE SEEN A 28X10.5 FIT ON A 97 , YOU CAN'T HAVE THE CAR HIGH I HAD TO LOWER MINE TO FIT A 28" TIRE ITLL RUB ON THE LOWER CORNERS OF THE WHEEL WELL, IM RUNNING A 325 50 15 ON A 15X8" RIM BUT I HAVE A NARROWER REAR END I USE A 4" BACKSPACE, CAN YOU GET A 15" RIM TO TRIAL FIT? ID GET IT ON BEFORE I ORDER A SET MEASUREMENTS DON'T ALWAYS WORK OUT NO MATTER HOW MANY TIMES YOU MEASURE, ALSO WHAT RIMS YOU GONNA RUN?
