First suspension mod?
Old Jul 9, 2002 | 12:32 AM
mitchntx's Avatar
Default Re: First suspension mod?
No, not rubber.
Poly ends vs spherical bearing end ...
And not all spherical bearings are created equal
Old Jul 12, 2002 | 04:33 PM
acarnut's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 94bird:
<strong>I'm really surprised I see noone recommending springs and shocks as the best first suspension mod. That is definitely what I would do first, and is what I did.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Good advice. We kinda got carried away on the bushing issue, but after tires, tires, springs and shocks will have a big impact on how your car handles.
Old Jul 13, 2002 | 08:23 PM
Dave Jones's Avatar
I too would like better handling with my car. It seems to roll a bit more than I would like on corners.
The car is a convertible. I've got a STB and Kenny Brown DD SFC's. The shocks and tires are original. Tires are 16" RSA's. Wheels are polished aluminum.
I'm thinking that I'll just get some Bilstein shocks. Lowering springs look like a lot of trouble and cost, and I'm not absolutely sure I would like the result.
Any suggestions would be appreciated.
Old Jul 14, 2002 | 06:00 AM
mitchntx's Avatar
While I never specifically said Springs/shocks, I did say "package" which should be included in any suspension upgrade.
As far as replacing shocks only because springs are a "lot of trouble", you will be pleasantly surprised to know that it's a real piece of cake, once you get the front shocks out. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Sorry ... couldn't resist. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
The front shock/spring combo is a crude coil-over design. You have to remove the spring anyway.
Old Jul 14, 2002 | 06:36 PM
Dave Jones's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by mitchntx:
<strong>While I never specifically said Springs/shocks, I did say "package" which should be included in any suspension upgrade.
The front shock/spring combo is a crude coil-over design. You have to remove the spring anyway.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What I meant was, apparently if you lower the car with new springs, you have to do a bunch of other things too -- things I don't understand.
Do you think it would be bad to replace only the shocks? Could you recommend one of the "packages" you keep refering to? I already have SFC's and an STB.
