Question on lowering with Koni's
Old Jul 11, 2006 | 04:26 PM
Velocity Boy's Avatar
Default Question on lowering with Koni's
I'll be going back to stock springs with Koni SA's soon. I will be setting the front springs on the lower spring perch which will drop the nose end about 3/4" as I'm told
Now on the rear, if I just leave it as is with the stock springs, will it look really disproportional with the front end? Do I have to do the hose mod on the rear or will it look ok without it.
I know these cars tend to squat alot under heavy acceleration, and I'm looking at 315's in the near future.
Any feedback is appreciated as well as pics
Thanks
Old Jul 11, 2006 | 10:02 PM
GTObsessor's Avatar
if u like the raked look on these cars (which I love myself), just drop the front 3/4" and call it a day.
Old Jul 11, 2006 | 10:43 PM
bearcatpride's Avatar
^^ Yep, what GTO said
Your car will look really aggressive with the nose end sitting slightly lower than the rear end
Old Jul 11, 2006 | 11:00 PM
Thanks guys, I'm gonna drop the front and leave the rear at stock height
Old Jul 12, 2006 | 07:47 AM
J. Brown's Avatar
I did both.............having the *** in the air is not the greatest for handling? Doing the hose mod gives the car the stance I believe these cars should have come with from the factory with the fronts set to the lower perch. Try just dropping the front and see if you like it..............it a simple process to do the hose mod after the fact.
Attached Thumbnails Question on lowering with Koni's-koni.jpg   Question on lowering with Koni's-koni2.jpg
Old Jul 12, 2006 | 11:13 AM
chupr0kabra's Avatar
Old pictures, but you get the idea. That was with Hotchkis springs up front and stock springs in the back.
-Mike
