Konis vs. Bilstein for daily driver
I am looking for the maximum benefit to comfort AND handling without compromising one or the other. It is unlikely that I'll actually use the adjustability of the Konis, at least once they are set up properly. Given I want improved all around performance with a bias towards comfort, are the Konis really worth more than double the price? I will eventually do Sam's sway bar combo, either at the same time as the Bilsteins or later if I go Konis. In my mind I see driving this car with Sam's sway bars and Konis on a soft setting but am wondering if Bilstein's will do that just as well sacrificing only adjustability. Is that crazy?
You can see from my suspension mods that I like to tighten and quiet the car down as much as possible. I have added MUCH sound deadening to the car with great success and will add more later. I'm wishing I'd done shocks first but now I can do them and maxmize the benefits of the mods I have done.
I would GREATLY appreciate input from those with firsthand experience with the Bilsteins and Konis. I'm trying to arrange a test ride/drive in a Koni equipped car to see for myself. Anyone in Houston got Bilsteins or Konis with stock springs?
Thanks!
Jason
So far I've been very happy, they are excellent shocks. Obviously you can't use them on lowered vehicles, but if my car sat any lower I wouldn't be able to get out of my driveway anyhow
-Mike
Do you have aftermarket springs?
If not, and if you want to save some $$$, there are other possibilities out there, and you will still have a nice ride.
Now...If you want the BEST, then Koni's all the way. The Single adjustable shocks will give you the options of changing springs depending on your preferences, so that's a good thing.
BTW, I've had tried a few different shocks on my first 4th-gen, I learned enough to know that either the revalved Bilstein's or the Koni's are THE best shock options for a great handling 4th-gen f-body.
Sorry. Too many things I can't know. www.stranoparts.com --814-849-3450
I'll be giving you a call real soon. I'm going back to stock springs and I'm trying to decide between the HD's and the SA's. My car is also a daily driver
Hopefully you can steer me in the right direction
Been thinking about this a long time and am getting ready to pull the trigger.
