Bad vibration/sound above 70mph(long thread)need help :(
the torque arms are touchy. i had the same problem. i changed the driveshaft and the panhard bar (adjustable). those took care of it. not sure which, but together they did the trick. is you rear of center. even a little.
Also for the u-joint.I ve test drive the car after the install of the new parts and i could hear the vibration with less then a miles driven(just the time to get to 70mph)so the u-joint are not the problem.
Always Faster, it sounds like you've been chasing that vibration gremlin hard!! You might consider checking one more hiding spot for Mr. Gremlin, the rearend. It might need new bearings, that's been a known cause of vibration/shimmy at highway speeds. My 2000 SS had a vibration like you've described when my worn out stock rearend was in the car. Since then I've replaced it with a rebuilt unit ( bearings, axles and such. ) with steeper gearing and... no more vibration.
My old 10 bolts was install on another f-body and no noise what so ever.
So this is not the issue.
Thanks for the help.
Originally Posted by BlackHawk T/A
Yeah I am also running new wheels/tires, and those didn't change anything. They are computer balanced also.
It is 100% drivetrain related and there is no arguing that. The car is smooth as soon as you put it into N...
(Sorry, I actually use the search feature on the site and sometimes drag up older posts)
I just put the BMR TA relocation mount on my car. I already had the adjustable TA and set the angle to -3 degrees and now at 80 mph it starts vibrating and just gets worse the faster I go. The car didn't vibrate at all before I installed it. Any ideas? I 'm not around the car right now but I just want to know what I should check first. I have the BMR LCA's, BMR adjustable panhard bar, BMR adjustable torque arm, BMR sway bars, and the car is lowered 1".
I am currently chasing the same problem...already flipped the driveshaft 180* will be having it balanced this week at which point the u-joint will be replaced.
It's aggrevating to say the least!!!
Change the pinion angle closer to -1 or 0.
-3 is pretty extreme on the street and i'll bet that's where its coming from.
It was at -3 before I put the mount in and at 130mph there was no vibration. The only reason I put the relocation mount on was I was thinking about putting N20 on and didn't want to break the tail shaft. The car was dynoed at 449.6rwhp.
