What brake fluid?
Old Aug 23, 2002 | 03:02 AM
TagUK's Avatar
Default What brake fluid?
Any recommendations? What is everyone using?
Thanks
Old Aug 23, 2002 | 10:17 AM
mitchntx's Avatar
Default Re: What brake fluid?
I use Castrol SRF
Old Aug 23, 2002 | 01:11 PM
Ben99Z28's Avatar
Brake and Clutch use the same fluid, stay away from DOT5 synthetic, I prefer ATE Superblue DOT4 fluid, it has outstanding wet/dry boiling point and last up to 3 years before you need to flush it again!! the superblue exceed most DOT4 and some DOT5 specs, good stuff....only $8~$9 a liter. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Aug 23, 2002 | 05:27 PM
WILWAXU's Avatar
Moving to the Handling section.
Old Aug 24, 2002 | 12:59 AM
CMNTMXR57's Avatar
For brakes or for clutch?
For brakes, Napa or whatever will work.
For the clutch, I use a DOT4 semi-synthetic (you don't want a full synthetic) as it stands up to the heat under their better than the DOT3.
Old Aug 24, 2002 | 11:38 AM
Dom's Avatar
Dom
Valvoline Synthetic is good up to 500deg and Mogul is even better.
Old Aug 24, 2002 | 03:34 PM
GREEN GOBLIN's Avatar
Is any synthetic o.k. ?
Old Aug 24, 2002 | 04:34 PM
Dom's Avatar
Dom
I used Valvoline Synthetic at the last autox. It was also recommended to me by a veteran road racer.
Old Aug 24, 2002 | 04:52 PM
Thanks! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
