CLUNK!!
Old Sep 5, 2002 | 12:21 AM
Diesel's Avatar
Default CLUNK!!
I could use some of the expert advice that's always floating around on LS1Tech!
I have recently developed a "clunk" noise on intial acceleration, and sudden decel/braking. I am thinking it must be a lack of lube in the LCA bushings, but before I jack the car up and check.....has anyone had this problem before,a dn if so what was the fix? Thanks gang, any help is appreciated. Aloha, Dave!
Old Sep 6, 2002 | 12:41 AM
Diesel's Avatar
Default Re: CLUNK!!
Nobody huh?........
Old Sep 6, 2002 | 01:21 AM
SStolen's Avatar
Default Re: CLUNK!!
Can you tell where the noise is coming from? Same thing happened to me. Don't laugh but it was the battery support. The hold-down had broken and the battery was floppin around in there. Just an idea.
<small>[ September 06, 2002, 01:22 AM: Message edited by: SStolen ]</small>
Old Sep 6, 2002 | 03:19 AM
Diesel's Avatar
Default Re: CLUNK!!
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by SStolen:
<strong>Can you tell where the noise is coming from? Same thing happened to me. Don't laugh but it was the battery support. The hold-down had broken and the battery was floppin around in there. Just an idea.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks for the suggestion. Actually I can feel it in the floorboard....probably need to tighten up or lube the LCA's, but was hoping someone might have an affirmative answer.
Old Sep 6, 2002 | 11:31 PM
nthnwbr's Avatar
Default Re: CLUNK!!
Sounds like you have a broken motor or tranny mount. Check that, it's probably your culprit.
<small>[ September 06, 2002, 11:32 PM: Message edited by: nthnwbr ]</small>
Old Sep 7, 2002 | 03:26 AM
Diesel's Avatar
Default Re: CLUNK!!
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by nthnwbr:
<strong>Sounds like you have a broken motor or tranny mount. Check that, it's probably your culprit.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Good idea....come to think of it, I should definitely inspect the tranny mount.
Old Sep 7, 2002 | 06:40 PM
PewterZ's Avatar
Default Re: CLUNK!!
Do you have aftermarket LCA's? I have Hotchkis LCA's and they make that clunk noise when I brake sometimes....Thats what it sounds like to me.
Old Sep 8, 2002 | 04:54 AM
Diesel's Avatar
Default Re: CLUNK!!
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by PewterZ:
<strong>Do you have aftermarket LCA's? I have Hotchkis LCA's and they make that clunk noise when I brake sometimes....Thats what it sounds like to me.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes, I have BMR's but they've never made this sound before. I also noticed a little bounce in the shifter today, so I'll be inspecting this weekend......I'll let you guys know the outcome when I find out! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
