Scraped Bottom of car
Old Sep 14, 2002 | 12:01 AM
Joe's Avatar
Joe
Default Scraped Bottom of car
Hey guys i was just wondering if scraping the y pipe and the subframe connectors once or twice is bad for the car. When i say bad, i mean as bad as changing the y pipe or having it checked. I just had the eibach prokit/bilstein hd installed today and i drove back to school. On the way out of a gas station I scraped the bottom pretty bad, i thought i got stuck on the ridge. Also, there were some pretty bad potholes on the 5. Please give your imput PLEASE!!! thanks
Old Sep 14, 2002 | 08:36 AM
GREEN GOBLIN's Avatar
Default Re: Scraped Bottom of car
I'd definately have a look at it, I wouldn't assume anything until I surveyed the damage...
Old Sep 16, 2002 | 10:13 PM
Racehead's Avatar
If you hit hard enough so that it stopped the car or you got hung up, then I would assume that some damage has occurred until proven otherwise. Take a good look.
Old Sep 17, 2002 | 03:54 AM
Joe's Avatar
Joe
One of my friends told me that if I did damage the y pipe or any other pipe that i could easily hear the problem. Is this true. Also i'm probably going to have this checked when i'm installing the cutout, but how do i make sure that the shop wont give me **** and rip me off
Old Sep 20, 2002 | 07:21 PM
TomQ's Avatar
well, think logicaly,
you scraped your y-pipe hard, what can be the damage ?
it can be bent over, kind squashed, or has a hole(s) on it, so you will be able to hear it because it will produce the kind of effect of the cutout, will be louder then your stock exhaust..
just my 2 cents <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
Old Sep 22, 2002 | 10:54 PM
xaon's Avatar
you would have to get under the car and see exactly what you are hitting and how bad. Mine is lowered 1-1.5" and I scrape my y-pipe all the time on speed bumps if i'm too lazy to do a big angle cut. Just be careful in the future, these cars scrape enough at stock height, not to mention what they're like when they're lowered.
Old Sep 24, 2002 | 12:11 AM
mitchntx's Avatar
The mounts on the exhaust are rubber and the pipe will give quite a bit.
