will suspension parts work on 12 bolt?
im looking to up grade my suspension, prokit, shocks, sub frame conn, LCA and relocation brackets and pan hard bar, and was wondering if i do this now, will the parts transfer to a 12 bolt down the road?
Also out of the things i want to buy, what would you recomend, the protit isnt deffinite, just looking for that kind of drop. anything else you think i should get, its a street driven Z28 that loves going to the drag stripe, just looking for a little more look out of it, and some better handling.
I also have a set of OEM ZO6 wheels sitting in my room for the spring!!
They will all work. The only thing that will need to be changed is the sway bar mount to the 12-bolt since the axle tubes are a larger diameter.
The ghetto way out is to buy 3" U-bolts and BFH the mounting plates.
Energy Suspension sells a 3" sway bar mount kit for ~ $60.
Sterling.
Sterling.
