fixing a bent torque arm possible? *pics*
if you look close i think the torque arm is bent where you adjust it.someone told me that its called the hine's(sp?) joint.
can i buy replacements to swap them out?
Originally Posted by chupr0kabra
It's a "heim" joint, and I bet if you call the manufacturer, they can tell you if those parts are available.
-Mike
-Mike
Originally Posted by weaponZ
yup,just got the email yesterday with them saying all the parts i need to fix it will cost me 39.99.not bad
LS1Tech Premium Sponsor
Originally Posted by RrCoX22
some bullshit.... shoulda got it for free
Lee Spicher
lee@bmrfabrication.com
(813)986-9302
Sadly, Lee probably posted in this message to clarify that the part was in an accident so that there wasn't bandwagoning that "you should have purchased "X" brand instead as they produce a better product. Recall, BMR was one of the primary inovators and designers with these components...many of the others are just following their designs. There is a design curve where changes and improvements occur over time of course...
free replacement...If its under warranty, then possibly...otherwise, there is no validity or this component replaced for free. If he did recieve it for free, it certainly would be a kind gesture that BMR would have gone far above what was necessary. ...same goes for GM and replacing one of their components that are not under warranty.
This is nothing against you RrCo so no disrespect intended. It never fails to amaze me how folks expect companies to warranty parts forever...let alone being a race piece which typically is not under warranty or very limited to manufacture defects or workmanship.
Some of you guys complain that aftermarket parts are so expensive and want them for almost nothing, when things are offered at very cut-rate pricing, then they want the vendor to warranty their product for the life of the car.
Maybe a solution as with GM or Sears would be to purchase an additional warranty would be something to consider or ask your manufacture or vendor to consider.
Purchase an engine, blow it up after a few runs or a season and see how well it would fly that the engine builder would repair and replace those parts for free.
Originally Posted by LS1FIRE
Curious to know where the car was hit to cause the torque arm to bent? Somthing else could be bent to?
