NEED HELP!! want springs 1" drop springs
I really don't want to drop my car too low and I'm planning on running OEM Z06 wheels when dropping my car. Where can I get springs that will only drop about 1"(1.25" the most!!!)?? And what would be a good tire setup for these rims(remember, 17x9.5,18x10.5)?? Please help!!
Re: NEED HELP!! want springs 1" drop springs
Tire size is more important for the rear rims. I am doing the same thing oem ZO6 17x9.5 285 and 18x10.5 305 with nitto tires. And I did not whant to lower because of pass. side turbo siting so low. I had hals in the front but they suck for autocross (car hit ground under heavy brakeing). If you are thinking the back tires will hit when you hit the gas hard, then your right I am useing 2 air bags in the spring. for load at the track and quick weight transfor with out the *** end bottoming. Oh I am useing Eibach 1" more like 1 1/2" .
