This does NOT look right
Old Jul 18, 2006 | 03:31 PM
Jimmard's Avatar
Originally Posted by 98 Raptor TA
You need to get BMR relocation brackets to take care of that, that'll prolly help your 60' also.
Yeah those are on the to-do list, but I think I have bigger problems to fix right now. What are everyone's opinions on DMS springs? How much will it raise my car?
Old Jul 18, 2006 | 03:35 PM
Viper's Avatar
That's alot of stero eqpt/weight to be runnign around on a lowered car.
Old Jul 18, 2006 | 03:41 PM
ssPetess's Avatar
I'm happy with mine, although i just have them in the rear. I sold the fronts, i prefer the linear rate of the pro-kit up there. Here the stance of my car with pro-kit up front and DMS out back.
Old Jul 18, 2006 | 05:40 PM
Jimmard's Avatar
I figure its no worse than having someone sitting in the back seat . Rarely does anyone ride in this car other than me. Once in a great while I'll drive my friends somewhere. I'd imagine its just riding on the bump stops then
That's because you dont have those spacers above your bump stop like he does. really he should just take those out but i guess he's scared he's gonna rub his tire on the inner fender lip. Unless you're running really wide tires (315's or bigger), i wouldn't use those spacers.
I'm running nitto555Rs 275/40R17 and if you can assure me that they wont rub witout the spacer there, I'll pull them out tonight and see if it helps. I love the stance of the car, but there is just not enough travel to drive it every day.
Old Jul 19, 2006 | 07:25 PM
Jimmard's Avatar
Well, I pulled that little spacer out and WOW is all I have to say. It has eliminated most of my bottoming out problem. Amazing what 1/2" more travel will do for ya when yo only had 1/4" or less travel to begin with. When it does bottom out, it seems like a lot softer of a hit. I haven't had any rubbing issues with the tires so I'm assuming that spacer isnt even needed. Why did they bother even putting that thing on there if it doesnt really do anything? Anyways, thanks for all the help.
James
Old Jul 20, 2006 | 02:11 PM
Dal1as's Avatar
That's right, I removed mine. He shouldn't have a problem. The GS-D3's are probably about an inch and a half wider than the Nittos of the same size and I don't rub.
Old Jul 22, 2006 | 05:14 AM
hot black trans-am's Avatar
I got 285's in rear and don't rub and am still a good distance from the lip.
Old Jul 22, 2006 | 10:14 PM
blind527's Avatar
Bump stops aren't completely necessary. I've had mine off for quite some time w/o any problems.
Old Jul 22, 2006 | 10:28 PM
oneBADDz's Avatar
Originally Posted by J. Brown
The bump stop spacers are on there for a reason. The SS came wih larger wheels........hence they will bottom sooner than say the standard 16" wheel. The spacer prevents the larger wheel from hitting the inner fender under full compression situations........which right now you have all the time. How many hundreds of pounds does your stereo equipment weigh?
Bigger rim with less sidewall, they are the same overall height as the 16s.
Old Jul 23, 2006 | 02:21 AM
Jimmard's Avatar
I think he means wider. I've had them off for a while with no ill effects. Every time I hit a big bump, where I would normally hit the bump stop, I can hear it mashing up against my exhaust going over the axle . Oh well, it'll make room for itself.
Oh and I checked out my rear shocks today after cleaning them up and driving on them for a while. They are leaking . Because I'm not the original owner, koni wont help me out will they? Can I get konis rebuilt or am I out some nice shocks?
Old Jul 23, 2006 | 02:43 AM
blind527's Avatar
I've never had a problem with my car bottoming out. I think it would take a pretty damn big bump to fully compress the springs!
Old Jul 23, 2006 | 10:45 AM
  #32
WayneSS01's Avatar
I have a prokit and bilsteins. Initially I removed the bumpstop spacer. Then changed to z28 bumpstops. They have more of a pointed shape as opposed to the blunt flat shape of the SS/WS6 bumpstops. On the few occasions the rear has bottomed out, the contact is not as forceful.
Old Jul 23, 2006 | 10:09 PM
  #33
ssPetess's Avatar
Yes, I did the same thing...
Old Jul 23, 2006 | 10:54 PM
  #34
Brandon Boomhauer's Avatar
thats my old t/a with a prokit and a iron block up front.
had 9.5s on back with 275s.
So why was the spacer put there in the first place?
